Hello, can you suggest a PSU for the following components:
Patriot Viper 4 Series 16GB DDR4 3200MHz CL16 Dual Channel Kit
ASRock B450 Steel Legend
SSD Silicon-Power P34A80 512GB PCI Express 3.0 x4 M.2 2280
Procesor AMD Ryzen 5 3600 3.6GHz box
Placa video Sapphire Radeon RX 5700 XT PULSE 8GB GDDR6 256-bit
HDD 1TB WD BLUE
AMD recommends 650W, but many of you say it's overkill and a good 550-600W should be enough.
Thank you!
https://linustechtips.com/topic/1123226-help-me-pick-a-power-supply/
HDD 1TB WD BLUE
Thank you!
Hello,
I recommend this unit https://pcpartpicker.com/product/CdLypg/rosewill-power-supply-capstone550m
I also suggest to switch the motherboard for a B450 MSI MAX motherboard (A-Pro, Tomahawk, mortar or Gaming PLUS).
1 minute ago, Plouffe said:
Hello,
Thank you for the quick reply! Sadly, that PSU doesn't seem to be available in my country (Romania).
@Sajiko recommended a good unit but a budget one.
On the same tier (as the Capstone) are the RMx 550 or TXm 550 from Corsair too.
https://fr.pcpartpicker.com/product/bqVD4D/corsair-rmx-2018-550w-80-gold-certified-fully-modular-atx-power-supply-cp-9020177-na
https://fr.pcpartpicker.com/product/dDH48d/corsair-txm-gold-550w-80-gold-certified-semi-modular-atx-power-supply-cp-9020133-na
The only known good PSU i found is this for 600 Lei:
https://mediagalaxy.ro/sursa-de-alimentare-corsair-tx850m-850w-140mm-80-plus-gold-cp-9020130-eu/cpd/CSACP9020130EU/
There are more Romanian made PSUs there than Internationally recognized ones.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
