Yes, but it depends on the price.
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
It's good but liquid coolers are not as reliable and durable as air coolers,
And maintaining liquid coolers is a hassle.
You will need to refill the cooler in a few years,and clean the block if it has junk blocking it.
And there is the risk of a leak...
Air coolers are just there and you can just forget about them,
In the worst case scenario you will just need to replace a fan.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
Why would you refill? AIO liquid coolers are hermitically sealed and maintenance free.That is the point. For example I got a H100 which is still working fine, and has been in service since 2011. You need to clean the radiator once a while, but thats the same story with air coolers.
Because of problems like this:
https://hardforum.com/threads/refilling-a-aio-cooler.1919993/
45 minutes ago, Vishera said:
I don't see the issue. A guy is trying to repair an AIO. Likely got a warranty on that, but chooses to repair either way. Most AIO's got a 3 year warranty. Same goes for the card that OP posted. How likely is it that you see issues after the 3 years?
Read the whole thread,there is more there (Just 3 comments)
Ok a guy wants to make his own AIO, using old scrabs from other AIO's and is afraid of mixed metals in the "loop".
From AIOs that failed,
A lot of AIOs fail,but a lot of AIOs don't fail.
If you are willing to fix them then all is good.
3 years it probably won't fail.
Depends if it was a mining card or not I guess.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
https://en.wikipedia.org/wiki/Falsifiability
You might misunderstood me.
I can clear up any of my statements you want.
I don't think it's necessary, thank you.
Not like it’s something you would be able to notice or see an impact.
