https://linustechtips.com/topic/1123110-reccomended-motherboard-for-new-system/
Are you set on this part list?
Yeah, i didnt end up going with the Ryzen 3700X as im going to be usisn this pretty much only for gaming and im more accustomed to intel and feel more comfortable with it
Im saying this becasue you reccomended ryzen in another post
Alright, won't fight with you on that then.
One minor change I would make is the case- just to something with more airflow.
Motherboard I'd look at something like a Taichi or Aorus Elite
ok thanks, i ws just looking at an aorus a second ago
and what do think about the airflow on this case https://pcpartpicker.com/product/BBrmP6/fractal-design-meshify-c-white-tg-atx-mid-tower-case-fd-ca-mesh-c-wt-tgc
Meshify C is love ❤️
DDR4-3000 2x8GB kits start at $50, so that's a really expensive kit for some extra RGB LEDs. Also the cooler has a max RAM clearance (with front fan raised all the way up) of 44mm (maybe 1-2mm more), so the 51mm Vengeance RGB Pro won't fit. FYR the Trident Z RGB and Royal are 44mm tall, Neo 41mm tall.
ImageServer.php?ID=66de1a15640@be-quiet.
Desktop benching:
Oh yeah i totally forgot to remeasure it when i changed out my ram, thanks, ill probably go with one of those options
