Greeting community.
If you look at my current build, our power supply didn't last 6 months.  I was warned of this after we already bought the power supply.  We are looking for a good power supply that is somewhere around 700W.  We were looking at the EVGA SuperNOVA G1+ 750 W 80+ Gold (https://pcpartpicker.com/product/xTMwrH/evga-supernova-g1-750w-80-gold-certified-fully-modular-atx-power-supply-120-gp-0750-x1). Is this a good option or do you recommend another option?
Thanks,
birdflyer
R U L E  # 1   A b o u t   M e:   I   u s u a l l y   g i v e   D U M B   a d v i c e   a n d   y o u   s h o u l d   n o t   l i s t e n   t o  m e.
https://linustechtips.com/topic/1123048-good-750w-power-supply/
RMx
If you're budgeted, CX
What are you trying to power?
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041369
750 watts is pretty excessive, what do you need it for?
Primary PC:
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041432
24 minutes ago, Slottr said:
RMx
It is the build on my profile
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041436
A 550W unit would be fine
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041455
I would feel better with a 600W. Is the one we were looking at a good deal or is there something better?
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041468
What happened to it?
If it's only 6 months old you will be covered by warranty. Have it replaced.
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041484
Ya we will send it back under the warranty.
For some other reasons we have decided to go with a new one. Any suggestions?
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041489
The stuff that has been suggested so far has been good. You also don't need 750W for a Ryzen 2700X + RX590. Decent 550W for that system will be fine, but if you want to go with 650W then it won't make any difference either way (just cost an extra ~$10 or so).
The EVGA G1+ isn't bad, but there's likely better stuff out there for the same price. What's your budget? I'll assume the $100 or so the EVGA G1+ 750W you were considering is your budget. Could probably get a Corsair RMx or Bitfenix Whisper for around that price. If you don't care about having modular cables you could probably save a few bucks with the Bitfenix Formula. Have a look what's on sale since there should be a few good deals coming up.
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041510
I would say $100 or less. the only reason I have built another system with that Power Supply and it has been great. thanks for the recommendation.
https://linustechtips.com/topic/1123048-good-750w-power-supply/#findComment-13041525
