CPU cooler not working properly or reached its limit? Mugen 5
7 minutes ago, aa55555 said:My chip does 145w package power when running small FFTs with AVX stress test.
The Mugen (6 heatpipes, thicker body) with fan speed around 1200rpm does 79c in 24c room temp with delta of 55c, if the fan in 3000rpm it drops 3c.
The MA410P (4 heatpipes, thinner body) with max fan speed did 77c and that is only 1c more than Mugen in same max speed.
I thought the cooling performance of Mugen will be a lot higher than MA410P because of its size? but turned out only 1c difference, so this does really make me suspect if the Mugen is working 100%.
Thermal conduction between CPU and heat spreader could be a problem also. As the two coolers show almost identical results and the CPU is 1.5 years old.
The MAX cooling performance of the Mugen is higher. A Ferrari running at 60mph is no faster than a Prius running at 60mph. The Ferrari can do it in second gear is all.
