Display 2 isn't active and no signal
Hi!
So today I booted up my pc as usual but my 2nd monitor says it isn't receiving an input. I tried:
  • Restarting the pc
  • Install the latest GPU drivers
  • Pull the cable in and out
  • Try a different GPU slot
Nothing worked. Now I went into my monitor settings and it does recognize the monitor, it still knows its name and it says it's connected to my GPU, but when I go to its settings it says the display isn't active. The monitor is connectd through a DisplayPort cable. How can I fix this?
Thanks!
Zemiox
https://linustechtips.com/topic/1122980-display-2-isnt-active-and-no-signal/
