Building a new pc need help placing fans
Depends on how well this case is designed for airflow.  I couldn't find any info about a h12i so i dunno.  Try your first set up and monitor your temps then play around with the configuration and see if it makes any difference.
perhaps a H210i?
I'd put a corsair and a NZXT in the front, and a nzxt in the back for exhaust
What are your specs?
On 11/12/2019 at 9:17 AM, bluethreat said:
Ryzen 7 3700x
wraith prism
asus x470-I strix
16gb of 2x8 Corsair lpx 3200mhz
zotac 2070 super twin fan
h210i
evga supernova gm 650w
Sorry for the late reply -- this got buried under some other tabs.
You could just add the ML120 Pro to the front for intake right above the psu shroud and under the graphics card fans. The stock fans can be left as exhaust at the top and rear.
