Hi all,
I'm having issues with my current build not booting, and I was hoping someone may be able to chime in on a solution. I've booted the build successfully before so I don't believe any parts are faulty.
First, the build:
  • CPU = Ryzen 7 3700X
  • Motherboard = MSI B450M Mortar Max
  • Memory = Corsair Vengeance RGB Pro (DDR4 3600)
  • GPU = EVGA RTX 2080 Super
  • PSU = Corsair CS650M
Issue = PC would not boot up when assembled, so I took it apart to troubleshoot. Found that motherboard does not boot or power fans when CPU is installed.
I have been troubleshooting this issue outside of the case using the motherboard box and I have tried the following:
  • Test #1:  Boot motherboard with nothing installed except 24 pin and 8 pin connectors.
    Result = PSU fan spins and EZ Debug LED lights up the "CPU" light.
  • Test #2A: Boot motherboard with a minimal setup (CPU, CPU Cooler, 1 stick of RAM, GPU and PSU with 24-pin and 8-pin connectors connected).
    Result = No boot or any fan spin. Mobo lights do not light up (including EZ Debug LED).
  • Test #2B: Boot motherboard with a minimal setup using different components (Ryzen 5 2600, GTX 1060, EVGA SuperNova 1000W PSU). Tested attempted using different combinations of the components.
At this point I assumed it might be a BIOS issue, so I did the following:
(BIOS taken from https://www.msi.com/Motherboard/support/B450M-MORTAR-MAX)
  • Test #3A: Clear CMOS by jumping JBAT1 for 10 seconds. Then, attempt boot with minimal setup.
  • Test #3B: Remove CMOS battery for 30-60 minutes, reinstall and attempt boot with minimal setup,
  • Test #4A: Attempt to update BIOS by using BIOS Flashback button and latest version found on MSI's website put onto the root of a 4GB FAT32 formatted USB drive. This was done with no components installed and the 24-pin and 8-pin power connectors connected. Test also attempted with another 4GB and 8GB FAT32 formatted USB.
  • Result = BIOS Flashback LED does not flash at all, and the motherboard boots up after a few seconds, spinning up the PSU fan and lighting up the "CPU" EZ Debug LED. After this, I attempted to boot with a minimal setup to no avail.
  • Test #4B: Attempt to update BIOS by using BIOS Flashback button and latest version found on MSI's website. This was done with minimal components installed.
  • Result = No boot or any fan spin. Mobo lights do not light up (including EZ Debug LED).
  • Test #4C: Attempt to update BIOS by using BIOS Flashback button and latest version found on MSI's website. This was done with only RAM installed (attempted 1 stick and 2 sticks in dual channel).
I assume the BIOS Flashback button does work and the LED does light up, as if I press the button with no USB attached, it flashes 3 times (to signify it was not able to find the BIOS file). This also happens if I use an NTFS-formatted USB drive.
After this, I was curious if I would get the proper lighting sequence for the EZ Debug LED. People online have said that the CPU light will light up for ~3 seconds, then turn off. Then, the DRAM light, then VGA, then BOOT. Since I only ever got as far as a solid CPU light, I did the following:
  • Test #5: Boot motherboard with only CPU, CPU cooler, and PSU attached.
  • Test #6: Boot motherboard with RAM, GPU, and PSU attached.
  • Result = PSU fan spins, RAM lights up, GPU lights up and fans spin.
Now I'm stumped and no amount of Google-fu has been able to solve my issue. Anyone have any ideas as to what might be wrong or potential solutions?
Thanks!
Update (2019-11-15): MSI swapped my B450 Mortar, which had the exact same issue. Assuming they couldn't fix the issue with that board, I will be sending my B450 Mortar Max for RMA as well. Thanks for the replies.
Edited by Fyuusha
Resolution
21 minutes ago, Fyuusha said:
Just return/exchange the motherboard
X570 ASUS Prime-P boards are down to $125 now
2 hours ago, OlympicAssEater said:
Seems like you got a DOA or defective mobo
I would assume this as well, but this exact same issue also happened to my B450M Mortar (non-max) last month. Just sent that for RMA, but I had used that for over a year before this happened. This new B450M Mortar Max was good for a few days before it fubar'd.
I was also unable to update the BIOS on MSI B450 Tomahawk MAX... and I did everything as instructed... It just wouldn't detect a BIOS...
Returned the POS (also had frequent random reboots) and flashed the BIOS of my B350M Mortar instead, which worked (after several tries eventually)
And yes, it's incredibly hard to find a solution for these problems, MSI  "support"  is no help at all.
I'd suggest return the mobo and try with another one as most likely yours is defective.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
