When I click or try to drag the little blue line in the timeline area it doesn't move until i tell it to play. The little blue marker in the playback window works great just not the one in the timeline window where you put all the video and audio tracks. Not sure if it's my system because this wasn't an issue with CS6 version but my specs are i7-7700K 4.2ghz, 16gb ram, SSD, Radeon 580, z-270 mb. I'm not an editor just a hobbyist, but i've read I need an Nvidia GPU? Actually none of that window responds well, clicking on the cut tool or the select tool or changing the zoom etc.
I finally gave up on my premiere pro CS6 and am paying full price for all the adobe cloud creative (CC) these issues are with the CC version not CS6
Other notes: CPU usage is 30%, GPU is always 5% when scrubbing the CPU graphics go up to 15% not sure why my card isn't being used.
and ... why does premiere use my internet so much while its on? 400kbps constant?
is there an optimal config for this that will help? I have a GTX 1060 somewhere would that help?
  • 4 weeks later...
