My screen flickers at 100hz, but not at 60hz why might that be? is there any way to fix it?
So, a couple months bought a new monitor, an MSI Optix MAG341CQ 34.0, and noticed that it tends to flicker, especially on grey things, just recently I tried setting the refresh rate down to 60, from the native 100, and that seems to have fixed the problem entirely. While the flickering doesn't bother me too much in most games, it can be a bit annoying, and I've been befuddled as to why it's fine on 60, when from most of the crap I've read says that it should be worse on lower refresh rates, it's really appreciate the help, thanks!
Probably poor cable quality. If you're using the included cable out of the box are usually garbage quality. Try a different cable.
"Black Out"
Dedicated Streaming Rig
Do you mean continuous flicker, or occasional signal drop outs?
a really bad implementation of black frame insertion maybe? no really i got no clue
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
Its probably got PWM backlight.
See if u have any settings to tweak in regards to smooth motion and BFI.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
