so i have a maximus ranger vii and a M.2:A2000 250GB
but it kind of works but whenever i boot into windows it works for some time and then windows stops responding to anything and i end up turning the power switch to 0 on my PSU but its really frustrating because whenever i play games it does it too i dont know if its because of the mobo or the ssd .-. can someone please help me out with this one ;-;
https://linustechtips.com/topic/1122613-m2-not-working-properly-how-do-i-fix-that/
Sounds like you have larger issues.
Give me the full specs on your system, please.
When did this issue start?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
That could be any number of things. Potentially even graphics card. What are the symptoms of the crash?
Primary PC:
my specs are: ROG Maximus Ranger VII, intel i7-4790K at 4,48GHz, ROG strix RX480 8GB, H105, M.2 SSD A2000 250GB Kingston, 16GB DDR3 1369MHz
and the problem started when i had the new ssd
i dont really know well the only thing is that it just freezes and does nothing anymore till i turn over the power switch on my PSU because if i just click the force restart button my mobo doesn't detect the ssd at all
So is it using that adapter thing at the top of the board?
May have to check the lane layout and see if it’s a bandwidth issue. Though I didn’t think it would happen like that. But worth a shot.
You have other stuff in the pc I assume. Other pci devices or more drives right?
What slot is the gpu in?
Just in pci express 2.0 x8
So what about the rest?
