High End VA monitor vs Mid range/budget IPS for Design and side gaming
I'd say a VA + calibration with a device.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
31 minutes ago, CpuTemps said:
Can you suggest a decent calibration device?
Datacolor Spyder series
or
X-rite i1 series
As for the monitor.
A top end VA can be as good as IPS in regards to color coverage and accuracy once calibrated. However its easier to find IPS panels that do that.
BUT with IPS u have to deal with IPS glow and uniformity issues as they are inherently less uniform than VA.
IMO a top fo the VA is a good bet. BUT, and its a big BUT. For gaming, dont expect to find a high color coverage VA panel that is fast enough to avoid ghosting/blurr for gaming. You have to choose 1 or the other.
it'll depend on the DCI-p3 and rec 2020 color coverage you want.
below is a link to a filter of rtings reviews. it should show 80%+ dci-p3 and 60%+ rec 2020, arranged by pixel response time, with frequency, black uniformity and panel type.
https://www.rtings.com/monitor/tools/table/13913
The Philips Momentum listed there is good in the results BUT as its a TV panel it has issues with crosshatching when used for PC use. This is caused by the BGR subpixel layout. As such i would not recommend getting it.
The Acer predator X27 is probably ur best bet. (IPS panel)
https://www.rtings.com/monitor/reviews/acer/predator-x27
Its far from cheap however at over $/£1500
The Dell S32220DGF is another option that may be good enough for u. ( VA Panel)
https://www.rtings.com/monitor/reviews/dell/s3220dgf
its a roughly $/£ 500 monitor.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Nah, you will be fine with a VA monitor for gaming too. Heck, I got the BenQ 2280 VA monitor for €99 and use it for allround, even for gaming:P
IPS sucks big time in terms of uniformity and IPS glow. I'm done dealing with that shit. And VA has much better blacks too which it's very important to me and I also use my pc at night and enjoy the dark scenes in games and movies.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
