I need help choosing a 144hz 1440p Monitor!
so recently I've been wanting a monitor upgrade. I currently have 2 crappy 60hz 1080p benq monitors and want to switch to possibly a 1440p 144hz 27inch main monitor (used for editing/design and gaming) with a vertical orientated one to the side for discord, spotify and other stuff. 120hz could possible even be fine. but forget about the secondary one for now. I was just wondering if anyone had some suggestions. I was also wondering with 144hz whether there was much of a noticible difference between 1 and 4/5ms response times. I'm not a pro gamer or anything but I do play competitive game modes in... rocket league and would like a good experience. I also ideally want decent colour accuracy but I realise this is a lot to ask for this budget. speaking of budget mine is around $500 aud which is around $350 USD. Any advice or help is appericiated :) also I have a gtx 1070 if that helps (idk) so that, along with my budget is why I want to go with 1440p.
https://linustechtips.com/topic/1122296-i-need-help-choosing-a-144hz-1440p-monitor/
This is what u requested (and yes, will be over ur budget)
-> https://www.pccasegear.com/products/45960/acer-nitro-vg271up-qhd-144hz-freesync-hdr-ips-27in-monitor
This what I recommended (slightly worse than what u requested. but doesn't break ur budget)
-> https://www.pccasegear.com/products/44105/samsung-jg50-qhd-144hz-curved-27in-monitor
Primary PC
CPU: AMD Ryzen 7 5700X3D | GPU: Zotac RTX 3080Ti 12GB | M/B: Asus ROG Strix X370-F | RAM: Corsair Pro SL 3200MHz 32GB | SSD: Samsung 960 Evo 250GB / Samsung 870 Evo 1TB | HDD: Seagate EXOS X16 16TB x2 Raid 1 | Power: Corsair RM850e | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung CHG70 27" 2K 144Hz VR: Pico 4
Secondary PC
CPU: AMD Ryzen 5 5600 | GPU: Asrock RX 5700 8GB | M/B: Asrock B450M Pro 4 | RAM: HyperX Fury 3200MHz 32GB | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung CFG73 24" FHD 144Hz VR: Meta Quest 2
Thanks for reading
