Bluetooth / Wifi motherboard antenna change
By
Kc7vwc
in Networking
in Networking
Solved by Pixel5,
it should work, there are usually no extra antennas in the original ones that are used for bluetooth as its also just using the 2.4ghz band so it can be run over the same antenna as the 2.4ghz Wifi signals.
turtles_vrywhr ·
Posted in Phones and Tablets0 -
ServalNullXero ·
Posted in Displays0 -
2
8
BeefyTank77 ·
Posted in PC Gaming1 -
derekchan ·
Posted in Graphics Cards1 -
1
Seedyboi_321 ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
If Buying Isn’t Ownership Then Piracy Isn’t Theft - WAN Show June 20, 2025
