Hello, i need some help. I got a new 144 hz monitor mainly for cs go. The thing is, i have rysen 3 2200g apu, without a dedicated graphic card, and a motherboard that i will give a link to at the end of the post. In the description of the motherboard, it says that it can run 60 hz @ 1080p. Now the thing is, by my logic, it should have been able to run at least 100 hz on lower res, since i was able to get 85 hz on my old CRT 19" samsung monitor through VGA connection, until i get a dedicated graphic card, so i can run full 144. But, when i connected the new monitor through DVI - D, it gave me only these options on lower res https://prnt.sc/puod0n , which didn't make sense to me, since like i said, i was able to get 85 on my old monitor. Is there anything i can do to fix this so i can get a little bit higher hz on lower res ? Thanks in advance !
Link to the motherboard: https://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=880
https://linustechtips.com/topic/1122060-problem-with-monitor-and-motherboard/
