6 minutes ago, jackan214 said:
If you have any questions what the text below the ports read just describe which one an I'll answer
Just to understand what you actually did, you had an existing PC and replaced the Motherboard (and possibly CPU?) in it?
You don't have to plug anything in there if you don't want to. All of the ports there are for front USB, front audio, Power Button (this one might be important), Power/HDD LED or maybe an internal fan.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Look in the manual of your motherboard. One of there should be your front panel connector, where you plug in the power button and power light etc from the case. Also one of those should be called HDAudio. Thats where also from the case the front panel connectors for audio (headsets and stuff) go. Also there could be the need to plug on USB connectors from your cases front panel. Depending on your setup there also could be a connector for RGB stuf.
Best practice is to check the wires coming from your case and referring to the MOBOS manual to see wich goes where.
And you cant really break anything :)
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
Yeah I had chassi, gpu, etc but I switched cpu and imo my very old motherboard wasn't compatible, the power button not being plugged in is probably the reason it won't start so if u could explain which port that is it would be very helpful
Aight ty will check the manual, it's just thicker than a bible so I didn't want to result to that before all other options have been eliminated
Thats the part where everybody has to check the manual when building with a new MOBO :P
Sometimes they are labelled on the board. Sometimes they are not.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
A corollary to go with your statement...sometimes the person reading the labels on the board understand what those labels mean, and sometimes they don't.
