Hi i wanted to know your opinion about this config but some things you should know before
- i know buying this windows is shit but i don't want to do the install because this friend suck with computer science like really
-for the same this is why i don't put too much storage because i don't even know he gonna use the HDD so
- i live far from me so i can't build it for him so this thoses options if i got a problem he can just tell the website and have a full support
- I don't take a AMD GPU because got one who be dead after 1 years and bad overall experience with amd gpu
So i you guys want to change some part or even the monitor because i suck at choosing a monitor if you got some good monitor for 144hz FHD and good color ms ...
Thanks guys :D
https://www.topachat.com/pages/configomatic.php?c=4dpwYCn4%2BamjwxigwTj669T9eSVCmDdSxi0Vvizn0y4%3D
https://linustechtips.com/topic/1121435-help-config-for-a-friend-of-a-friend/
Memory: 3200 CAS18. the timings is very loose comparing to typical CAS16 kits. If 3200 CAS16 cost too much, get 3000 CAS16 instead
SSD: Samsung SSDs are overpriced in general just by being big and carry premium image (except PCIe 4.0 SSDs), they are good but not worth the money. I cant see what else you could buy but my typcial choice are the Adata SU800 and Crucial MX500
NZXT cases dont have impressive airflow in general, not one I would go for with a high heat output GPU like that
750W PSU is overkill, this build can't even use 400w max
Desktop benching:
