Is a Ethernet connection faster than a wifi card? If not what are some great wifi cards.
Thanks for your time:)
  • CPU
    AMD Ryzen 5 2600x 3.4 GHz 6-Core Processor
  • Motherboard
    Gigabyte B450 AORUS M Micro ATX AM4 Motherboard
  • RAM
    Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
  • GPU
    Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card
  • Case
    Thermaltake Versa H18 MicroATX Mini Tower Case
  • Storage
    Crucial MX500 500 GB 2.5" Solid State Drive
  • PSU
    Corsair VS 550 W 80+ Certified ATX Power Supply
  • Cooling
    Deepcool Gamerstorm Captain 240 PRO
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1121421-whats-faster-ethernet-of-wifi-pcie-card/
Depends on your network setup
But ethernet will almost always be more efficient
Generally wired is faster, but in my opinion the reliability of ethernet is much better.
But of course you could have shit wiring and very good WiFi, or vice-versa, so I can't say for sure what would be best.
If you can, I recommend running an ethernet cable. Otherwise, Asus makes decent network cards, be sure to get one with external antennas you can move though; as otherwise the antennas are just on the back of the case (where WiFi wont be great)
My internet is very inconsistent. It has random drops. And it really slow.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
A number of things can cause that but generally going wired is great at eliminating half of them.
Ethernet (or simply known as wired) is king.  It always will be.  WiFi has it's place to be sure, but even WiFi cannot exist without Ethernet somewhere.
WiFi has two large disadvantages:
1.  Latency (gaming, VoIP, for example don't like high latency)
2.  Reliability (WiFi is subject to lots of potential interference)
Edited by LogicalDrm
Cable >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> WiFi
But 802.11ax (WiFi 6) is BLAZING if your ISP offers the speeds, and if you have no metal, concrete, thick walls between client and router or AP.
"Soli Deo Gloria"
IT Technician by trade. Computer/Network equipment enthusiast!
Gaming PC:
  • AMD Ryzen 5 2600X (Stock Core Clock)
  • XFX RX 590 FATBOY 8 GB (Stock Core Clock)
  • Asus ROG Strix B450-F Motherboard
  • Crucial Ballistix 16 GB (2x8) kit 3200 Mhz RAM
  • 512 GB Intel 660p M.2 NVMe SSD (Boot & Current Games)
  • 3 TB Toshiba HDD @ 7,200 rpm (Data)
  • 2 TB Seagate HDD @ 7,200 rpm (Backup)
  • Corsair CX650M PSU
  • NZXT S340 Elite Case
  • 24" AOC C24G1 1500r Curved Gaming Monitor 144hz 1080p
  • Turtle Beach Stealth 450 Gaming Headset
  • Corsair K63 10-Keyless Mechanical Gaming Keyboard (Cherry MX)
  • Logitech G602 Wireless Gaming Mouse, Razor Death Adder
  • Win10 Home
PC Part Picker Link
