You have to have an AIO? A lot of more compact air coolers will perform better than a single 120mm AIO. 8700K is a pretty hot chip if you want to OC.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
Some cases don't have the airflow for good air cooling, the H80i v2 is essentially a 240 radiator that takes up on fan slot.
If you can’t fit a decent tower cooler or a 240 aio or bigger, sounds like a better case is in order.
I've actually been thinking about upgrading my case but idk which one should I choose. Would NZXT H700i be a good choice if I wanted to put something like a NZXT Kraken X62
as cooling in it. I think it has enough space on the front but I don't really know how it goes.
If you want case advice, slap a budget and your desired features towards @TVwazhere, he's the resident case-lord.
Main PC
CPU: i5 12600KF
ODD: LG WH14NS40
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
3 minutes ago, Caroline said:
NZXT cases = no airflow + expensive
I cooled an OCed 8600K on an NH-D15S and two EVGA 1080 SCs in SLI (bottom card maxed at 66C and top at 76C) in an S340 Elite, known for "mediocre" airflow.
Though I can agree that they are overpriced compared to the competition, and IMO the H series isn't as nice as the S340 Elite was, aaand Fractal has the Meshify C for less and that's an excellent case (I just got my Meshify C Mini, will be building in it this weekend).
Main PC
CPU: i5 12600KF
ODD: LG WH14NS40
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
What are your specs and why do you only have space for one fan? Why do you want an AIO as opposed to an air cooler?
Where are you shopping / located? Budget?
