I would like to ask for your recommendation on a laptop for under USD 800. I would be using it for video editing and a little bit for photo editing on the side. I will be using Adobe Premiere Pro, Vegas Pro and Adobe Photoshop. UAE sites/listings are preferred.
https://linustechtips.com/topic/1121383-need-help-choosing-a-laptop-under-800-usd/
Currency conversion and how expensive things are in different places is difficult.
You're probably gonna want to go used, so my suggestion is that you go on a used UAE site and show us what are the options at the top of your budget. From there we can go on.
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
