I want to buy one of these coolers to use on a Kraken g12 2080ti setup.
I am leaning towards the H105 as its about +20% cheaper than the x52. I have read however that the H105 can have a noisy pump. I am sensitive to noise, hence the GPU cooling solution.
Is the x52 any better or do they all have a similar noise and I should just get the H105.
Thanks in advance.
https://linustechtips.com/topic/1121027-corsair-h105-vs-kraken-x52-noise/
22 minutes ago, AlexMullerSA said:
I can't say for certain but they look to be the same generation Asetek pump, and so apart from trivial things like RGB implementations they are equivalent.
Ok so the savings is worth taking the H105. Any idea how loud these pumps are?
