I need a proper battery UPS, so that I can run a printer on a mobile "taco cart" in tandem with my laptop for on the fly work.  I know nothing about this side of the tech industry and need help.
Need to be compact enough to fit into an area approx. 17" wide x 23" length x lets discuss height.
Needs to be able to power a printer (specifically a HP Laser Jet Enterprise M506) for multiple hours (80% of that time idle waiting for print command)
Laptop to be powered is a 2019 Xeon workstation so pretty power hungry
Basically I need to plug that in overnight to charge, when I get in the morning put my laptop on the cart (and power my laptop for a few hours would be a plus) and get mobile.
Any and all help appreciated - budget is....tbh whatever if it gets the job done it doesn't matter.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1121026-need-help-apc-ups-for-mobile-workstation/
USA
18 minutes ago, Legend1234-jack said:
What country are you from
then I can help you
USA, forgot to quote you
I could really use some quick advise on what will fit my needs (or if Im even calling it  the right thing) no deadline but I have a project I need to get implemented.
Ill do my own research if necessary but I know the people here are much smarter than Google + Me efficiency wise!
