graphics card doesn't work after upgrading motherboard and cpu
I upgraded my intel i3 6100 to an ryzen 2700x with an asus b450 motherboard and a GTX 1070 and when i turned it on i didn't get any kind of picture on screen so i switched the graphics card to my old graphics card a GTX 1060 and it works perfectly. The 1070 still works in my other pc without any problems but not in my new pc with the ryzen cpu.
did you tried to update your bios?
my current home setup:cpu:amd ryzen 2700 // cpu cooler :aigo 120mm aio // mobo:gigabyte ab350-gaming 3 // ram:crosair vengance 8*4 // gpu:amd rx 5700 //
tower:antec p8 // psu:antec HCG 650w.
my current work setup: cpu:intel xeon x5675 // cpu cooler :generic 6 copper pipe // mobo: x58 lga 1366 chines motherboard // ram: 32GB ecc // gpu:amd r7 260x //
psu:antec 550w.
my current home server setup:cpu:intel xeon x5690 // cpu cooler :aigo 120mm aio // mobo: x58 lga 1366 chines motherboard // ram:crucial 8*2 // gpu:amd rx 580 //
tower:antec p110 silent // psu:antec HCG 850w.
Update MBO bios. Check the 1070 in a different computer to see if it works. If it does work, retry in the main computer.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
50 minutes ago, jesout said:
The 1070 does work in my other computer
Ok, do the bios update, also check if there's a newer BIOS for the 1070 and flash that if there is.
Do you get no signal at al (as in does the screen not flicker at all)l, or do you get bios but no windows picture?
If that is the case, its likely the card is power starved or that it is a driver issue.
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
I don't get singal at all the screen is completely black. I can't get to bios
you have got your screen connected to the videocard and not the mainboard connection, right?
You mentioned you upgraded the bios. Which bios did you upgrade? The Mainboard or the VGA card bios?
the thing that doesn't make sence tho, is that the 1060 in the same system works . . . as they are essentially the same cards (sort off).
you are not running them side by side or in different slots on the mainboard? They are both connected on the same slot, as in you actually swap them out and don't leave them together in the same system?
Yes the screen is connected to the videocard. I upgraded the mainboard bios. I'm not running the videocards side by side i swapped them out and they were both connected to the same slot
