Will a be quiet System Power 9 500W be enough for my build?
9 minutes ago, Neymus said:
My build is a Ryzen 5 2600 with a RTX 2060, will it be enough or should I rather go for a GTX 1660 Super/Ti?
Get something around 550w or 600w if you wanna be sure.
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
no need, it can't even hit 500
1 minute ago, Neymus said:
I was talking about the voltage, even though I've heard that it's not recommend nowadays...
sp9 is dc-dc, so crossload or anything isn't a problem
whining is just the sign of an overloaded transistor, which is only annoying, nothing dangerous
So the whining is just a sound? Is it really that annoying or will I get used to it after some time?
some get used to it, some don't
and again, there's a chance, it's not guaranteed
31 minutes ago, LukeSavenije said:
you have a chance it can start whining, but otherwise it's fine
What?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
what what? it's a double forward
Explain to me what makes you think it can cause whining.
due to hard switching, which is quite direct with double forward
that's as far as i'm aware what causes the transistor to overload at certain loads, which aren't impossible to do with a 2060
hence the CHANCE of whining
