Hi i want to make a triple monitor setup but i dont know which monitors to choose
i want all the monitors to have te exact same look (stand doesnt matter cuz they are going to be on a monitor arm)
I want them to be 27"
and the middle one 144hz (gaming monitor) and the 2 side ones 60hz or 75hz (for stuff like discord spotify chrome etc.)
and all 1080p
and if possible gsync compatible
https://linustechtips.com/topic/1120711-triple-monitor-setup/
and all 1080p
There are people who are way better at choosing displays than me, ill let them find models. BUT even if you buy displays form the same manufacturer and panel type they will probably look different and you'll probably have to play will settings to get them to look almost the same (and even then it might still be slightly different)
why no dark mode?
Current:
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz, Asus VG248QE 1080p@144hz
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 512GB HP EX NVMe SSD, 2TB Silicon Power NVMe SSD
Displays: Internal 1080p@300Hz
Custom Game Server:
CPUs: Ryzen 9 9900X
RAM: 128GB (4x32GB) DDR5 @ whatever it'll boot at xD (I think it's 3600MTs)
Storage: 2x 1TB WD Blue NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
https://linustechtips.com/topic/1120711-triple-monitor-setup/#findComment-13022824
