As the new pc season approaches for me, I am on the quest to build the ultimate ARGB colorful build.
9 ARGB fans, ARGB ram covers/heatsinks, ARGB Strips. I know its over the top.
I am going for a total of 15 total ARGB devices.  And this is why im turning here. I want this build to be perfect in terms of color control and showoff.
I have raised some questions to myself as im trying not to use corsair fans.
In order to have 15 total ARGB devices i will have to double splitter the ARGB signal. The spliters are powered so im not worried about power output/draw.
Is it even possible first off to have this many devices connected to one ARGB signal conection on the motherboard.
And two, will i be able to controller each ARGB device independently of each other. I need each fan/strip to work independent from the other to make a light show happens. Having each fan do the same thing just doesn't achieve what im after.
Fan power and speed is already solved.
Or do i throw in the towel and get 2 CORSAIR RGB Fan LED Hubs routed through a Lighting node to control their 12 fans?
Thanks
https://linustechtips.com/topic/1120572-argb-build-of-all-times/
