I’m not sure if I want to do fan , aio or tubing . Would the aio leak?  I’m planning on getting the 2080ti and the intel 9900k
im sure water would be the best deal . I’m kinda worried about leaks or fixing leaks . Will it get more worst if I fix the leak . Removing and putting them back in . Or when I maintain it . What should I do fan aio or tubing ?
https://linustechtips.com/topic/1120525-question-on-building-my-first-pc/
Anything can happen. If you are worried, it isn’t for you.
Dont buy crap or treat it like crap and you won’t have any problems. But an aio is the biggest risk. Never had one leak myself. Nor have any one of custom loops lost me any hardware.
