So I’ve been looking back at the base model Xbox One and PS4 and noticed the Xbox One has slower RAM but it has 16 x 512MB chips compared to 8 x 1GB chips in the PS4. Which configuration is better? This is more of a curiosity thing.
Rainbow Barf
CPU: i7-12700K GPU: RX 6800 XT RAM: 64GB DDR4 Storage: 2TB NVME SSD RAID - 1TBx2 NVME SSD - 8TB HDD
Lenovo Legion Pro 5i
CPU: i7-12700H GPU: RTX 3070 Ti RAM: 32GB DDR5 Storage: 1TB + 1TB SSDs
technically the increased amount of ram chips on the Xbox would allow for more bandwidth
Primary PC:
It'll take some more detail to work out. What is the effective number of channels? How is the rank or chips per channel configured? Then throw on top of that the speed...
if other specs are the same then of course more chips is better, since each chip gets the same bandwidth. I dont know how many memory channels they're running though
Desktop benching:
Can't determine anything from chip count alone, need to see what chips they are, what bus width, what organization, what's the bus architecture of the system,...
F@H
GPD Win 2
well for consoles there are no memory channels, because they pool like a graphics card and then allocate dynamically
Primary PC:
change "memory channel" to bus width then, they're interchangeable here.
Desktop benching:
