I have the budget for a ryzen 73700x and a very cheap monitor 1080p used or a ryzen 5 2600 and the opportunity to pick a 144hz 1080p asus strix monitor what could be better I have already bought an rtx 2070 and I have the motherboard and the power supply corsair rm850x
long term it would be best to go with the 3700x and get a cheap monitor now and upgrade sad monitor later as its the cheaper option later.
"Black Out"
Dedicated Streaming Rig
R5 3600 gets my vote as well.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Just now, Josera12 said:
the thing is that im getting the ryzen 5 2600 for 100 dollars
The R5 3600 is your best pick... it games the same as the R7 3700X
The R5 2600 may be cheaper but it does game worse and might not be up for the task of 144fps on your games.
Personal Desktop":
Luna, the temporary Desktop:
I don'T see the point of buying an overkill CPU for the task you need and a shitty monitor, then sell and loose money with the old monitor and by a new one. Get a 100-120hz monitor and a 3600, it will get the job done and you won't notice the difference between 120 and 144hz. Buying something now because you can't afford the better product is a waste of money we all did here. Just my 2 cents
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
1 minute ago, Josera12 said:
but the difference between the 3600x and the 3700x in price is about 50 dollars here in Mexico and a cheap 144hz monitor can cost about 200 dollars
The 3600X is not worth it, get the 3600 you will save another 50$
