i recently bought a gpu its a r9 270x from power color im using a sata to pcie for power and i keep getting gpu crashes or somthing my system will still be on
but i wont get a signal i can barley get past the windows login help would be great thanks
-= Thread Moved to Troubleshooting =-
OP please post your system specs and add any more detail if you can about what is happening so we can better assist you.
 CHRISTIAN MEMBER
Get a power supply with proper PCIe connectors. That is a bad practise, especially for cards that pull a lot of watts.
And if you have a PSU that does not have PCIe connectors... it's possibly very old and should be replaced by now.
EDIT: SATA power connectors can't supply over 54W, GPUs can easily pull more than that. And using more than one SATA connector on the same cable is recipe for something really bad (maybe even fire hazard).
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
