I have a i5-9600k with a deep gammaxx 400 cooling it. its not over clocked. I was looking in open hardware monitor and one of the temps is constantly around 90-105 degrees. I already took off the cooler and re-applied new thermal paste and the temp stayed at that same value.
https://linustechtips.com/topic/1119877-i5-9600k-single-temperature-over-heating/
Probably a buggy reading. Ignore it, it's fine.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
This is a phantom temperature sensor, as well as the ones that show 20-something degrees. A multicontroller chip normally has several temperature inputs, but not all of them are used, so the software reports crazy values for such inputs.
