Hey, I currently have a build for a PC but is a little over budget for me. It is as follows:
CPU Intel Core i7-9700 3 GHz 8-Core Processor £317.98 @ CCL Computers
Motherboard Gigabyte B365M DS3H Micro ATX LGA1151 Motherboard £69.99 @ CCL Computers
Memory Patriot Viper Elite 16 GB (2 x 8 GB) DDR4-2666 Memory £61.87 @ More Computers
Storage Sabrent Rocket 512 GB M.2-2280 NVME Solid State Drive £59.99 @ Amazon UK
Storage Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive £49.99 @ Overclockers.co.uk
Video Card EVGA GeForce RTX 2070 8 GB XC ULTRA GAMING Video Card £458.99 @ Amazon UK
Case Cooler Master MasterBox Q300L MicroATX Mini Tower Case £41.19 @ Ebuyer
Power Supply Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply £70.68 @ Amazon UK
Operating System Microsoft Windows 10 Home OEM 64-bit £85.98 @ Aria PC
  Prices include shipping, taxes, rebates, and discounts
  Total £1216.66
Can anyone suggest something that is a little over £1100 (no more than £1150) with very similar specs to these specs
Also would be open to whole entirely different specs (prefer i7 9700 and a similar GPU to the current one, as long as it is a good build!)
https://linustechtips.com/topic/1119828-recommending-a-little-cheaper-build/
1 hour ago, ATKINNNNNN said:
You can get a windows 10 key for $5 on ebay
What's your monitor resolution/refresh rate?
The R5 3600 has 90% the same gaming performance at a lower price.
17 minutes ago, ATKINNNNNN said:
Streetguru, I made another post detailing as much information i can give you :).
It is in the same forums tab as this one
Someone will merge it eventually.
You're better off upgrading your display now, and buying a 2TB hard drive later on
That cooler is just a low price dual tower cooler. You aren't going to want water cooling in the Q300L, it's fine for air cooling though.
Could also get a 4k display if you aren't too worried about 144hz, or maybe just go all the way to 240hz, but you'd want 3600mhz CL16 RAM for that. Only useful for games like CS:GO though.
*And that RX 5700 is cheap because the cooler is pretty average/not impressive but it'll function fine.
PCPartPicker Part List: https://uk.pcpartpicker.com/list/ngPZRk
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£172.38 @ Aria PC)
CPU Cooler: ARCTIC Freezer Xtreme Rev.2 Fluid Dynamic Bearing CPU Cooler  (£33.46 @ Scan.co.uk)
Motherboard: MSI B450M GAMING PLUS Micro ATX AM4 Motherboard  (£77.98 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  (£66.78 @ Aria PC)
Storage: Intel 660p 512 GB M.2-2280 NVME Solid State Drive  (£62.47 @ Scan.co.uk)
Video Card: XFX Radeon RX 5700 8 GB DD Ultra Video Card  (£301.00 @ Amazon UK)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  (£41.19 @ Ebuyer)
Power Supply: Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  (£79.61 @ Ebuyer)
Monitor: LG 24GL600F-B 23.6" 1920x1080 144 Hz Monitor  (£139.99 @ Overclockers.co.uk)
Total: £974.86
Generated by PCPartPicker 2019-11-02 23:39 GMT+0000
