Hi. I'm using OBS Studio to record videos on my gaming laptop. I always tend to use Display Capture, which grabs the video from the display port instead of the application. The reason for this is simple. I'm planning to record not only games, but also some editing process (level design, programming, etc.) - for that I need Display Capture. But laptop uses two video cards for this purpose. nVidia GeForce GTX 1050 is like support card for 3D apps (games, modelling and rendering apps), while the main card is actually integrated, which is the one hooked to the display port. Display Capture uses that one. In order to actually grab the display screen, OBS has to be run on integrated video card since it cannot use both cards simultaneously. Settings that previously worked, are no longer in effect after I've upgraded my Windows 10 to Insider preview build.
This is my preferred video card settings for OBS:
This is black screen that's gonna be recorded in OBS (usually result of wrong video card choice):
And this is the log file that says what video card OBS actually chose - https://obsproject.com/logs/__RANt_uKWF671zG:
11:05:11.045: ---------------------------------
11:05:11.045: Initializing D3D11...
11:05:11.045: Available Video Adapters:
11:05:11.052: 	Adapter 0: NVIDIA GeForce GTX 1050
11:05:11.052: 	  Dedicated VRAM: 4214226944
11:05:11.052: 	  Shared VRAM:    4212287488
11:05:11.052: 	  output 0: pos={0, 0}, size={1920, 1080}, attached=true
11:05:11.052: 	Adapter 1: Intel(R) UHD Graphics 630
11:05:11.052: 	  Dedicated VRAM: 134217728
11:05:11.053: 	  Shared VRAM:    4212287488
11:05:11.059: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 (0)
11:05:11.966: D3D11 loaded successfully, feature level used: b000
11:05:11.966: D3D11 GPU priority setup failed (not admin?)
11:05:12.365: ---------------------------------
As you can see, it completely ignores my preferred settings and still choses nVidia, which won't work with Display Capture :(
What do you suggest me for solution? I can't simply abandon Insider, because I'm going to build cross-platform apps and I need Insider preview in order for it to work...
Quote
Only two things in the world are truly infinite: the Universe and human stupidity.
-- Albert Einstein
  • 5 weeks later...
Quick headsup. Update several times to newest Windows Insider build, and still doesn't work, still ignores my preffered graphics card settings. I am quite sure it is caused by Windows, but for some reason it only affects OBS, nothing else. Why's that? I don't want to leave Insider, I need those features for cross-platform development, which will also be subject for my videos, apart from gaming.
Quote
-- Albert Einstein
Update: I managed to solve the issue. Trick was in Windows video settings per application. Why OBS switched to that, I have no idea. But things do change, unfortunately...
Quote
-- Albert Einstein
