Help! Give me some advice!
Go to solution Solved by s7op,
Thanks bro's.
8 minutes ago, s7op said:
I'm a total PC noob i got questions for someone if they can please hop on discord or steam voice chat with me. :)
How's abouts you ask your graphics card related question right here, in these handy dandy forums?
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | [REDACTED] - 50GB US + CAN Data $34/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
you can type your questions here, or find youtube videos
Primary PC:
yeah but i'm level 2 in my typing stat, but ill try. Anyways, so in around 2014ish I bought a NVIDIA GTX 760 for my dell XPS 8300. I thinks its about time to upgrade the graphics card, i'm trying my hand at getting a Gigabyte 2050 ti for $80. I'm worried about the compatibility of the graphics card since I don't know a thing about this PC to begin with, let alone if the new will fit. Thoughts?
This is the graphics card btw: https://slo.craigslist.org/sop/d/paso-robles-gigabyte-1050-ti/7007669623.html
Just now, Genwyn said:
If you fit a 760 in there the 1050ti will fit.
Alternatively the RX 570 is dirt cheap used on eBay and would outperform a 1050ti. They’re about 90$ for a decent cooler model secondhand.
How much will it out perform? Also yes im well aware im going to be bottle necked by the i5 2300 on the pc
