I've built my own computers for years and worked with many gigabyte motherboards but I've never seen this kind of problem before. Everything works great until i flash the main bios to a newer version. Then it fails to load windows. However the back up bios works just fine, so it clearly not a hardware issue. I can access the main bios and change any settings but It won't load windows. It states there is no boot drive available. I thought this may have been a defective board as did gigabyte when i put in a ticket for technical support, However i got a replacement board from amazon as i thought the first was broken and now the replacement board is doing the exact same thing. It has to be a software option somewhere, but i can't for the life of me figure out what it is and have searched everywhere. Does anyone have any ideas? I've tried re-flashing the bios, clearing the CMOS, loading optimized defaults ect. but to no avail. The only post code is AA, which apparently stands for reserved whatever that is. Any help would be appreciated.
Thank you.
https://linustechtips.com/topic/1119568-crazy-gigabyte-x570-master-issue/
Whats the name of your Motherboard? What Bios version are you on and what version do you want to flash? Do you use a Sata SSD or a M.2 (NVMe) as the boot drive?
For example - i have the Z390 Aorus Master and i use a Samsung 970 Evo Plus NVMe M.2 - and i HAD to use the second M.2 slot since it would not show up in the top M.2 slot.
ESL Profile: https://play.eslgaming.com/player/2432327/
F@H Profile: https://folding.extremeoverclocking.com/user_summary.php?s=&u=847206
Old System:        Current System :
i7-3770k + Cooler Master Hyper 212                           i9 9900k + Noctua NH-D15
Gigabyte Z77M-D3H                                                    Gigabyte Aorus Z390 Master
Evga Geforce GTX 970 SC                                          GIGABYTE GeForce RTX 2070 SUPER GAMING OC (F@H OC +70core/+580 mem)
HyperX FURY Red 16GB  DDR3 1600                        Corsair Vengeance  LPX 2x16GB DDR4 3200
bequiet PURE POWER 600W 80+ bronze                  Corsair RM 650x 80+ gold
Samsung 850 Evo 120 GB + 1TB HDD                       Samsung 970 Evo Plus 500GB
        Thermaltake Level 20 MT ARGB
Wow really should have given that info lol.   It's a gigabyte X570 Master, Ryzen 3800X, and Samsung 4tb 860 Evo 2.5 SSD.   Everything is wired correctly as it boots just fine in the back up bios which is the factory F4 bios.   The new bios I flashed to is the F10, but i also tried F7, F6 and even going back to F4 but the same issue occurs no matter what.
The only thing i found so far is that people had to do a fresh windows 10 install, but i wouldn't bet on that since it was hard to find more then just a couple forum entries scattered around via google search. Someone else with actual knowledge is needed here, i am just a mere "meh, let me google that and see waht i find" guy :D
Do you potentially have to many things slotted on the motherboard taking away the PCI lanes needed for the boot drive to be recognized (I.E. and this is a longshot but maybe the BIOS updates changes how the lanes are split?)  Im not confident on this one.  Just talking out loud.
Id also suggest a fresh install using the BIOS you know works, then attempting to update BIOS after.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Do you see the drives in the BIOS?
Did you try booting from the installation file?
Did you try the repair function?
Maybe a GPT issue but that would be really strange...
Are you sure it's on UEFI? ( also makes little sense I think ?)
AMD 5900x, 2x16GB ( G.skill F4-3600C16 ), Radeon VII, Radeon 570,  Corsair 1200i , SSD 240/500GB, HDD 640GB,1TB,5TB, 1TB NVME. Lian li 011Dyanmic XL, big ass LTT mouse-pad & stealth water bottle
1 minute ago, Leanora said:
I doubt there are too many things taking up PCIE lanes. Just a 2080 TI and to Sata drives.
I can see the bios and select it but i just get a aorus logo thats constantly trying to load windows but never does.
I've tried UEFI, diabled and legacy, it doesn't seem to make a difference
I'm stumped.
Try  min config but with the OS disk in and see what happens
boot from the win installation file and try repair, if that does not work a fresh install.
If you are not able to reinstall it, then I have no idea what is going on at all.
Did you contact gigabyte and if so what did they say?
