Hi,
I have a strix Z270i motherboard and it has a 4 pin RGB header. I was wondering what the best 120mm fan would be for this motherboard with RGB capabilities. My cooler is also a kraken x52. My MB is also compatible with aura sync but almost all the RGB fans im finding are wither 3 pin or are 4 pin but super loud.
Any suggestions?
Thanks
https://linustechtips.com/topic/1119438-looking-for-compatible-rgb-fan/
