I've been thinking about getting a vertical grip for my D500 for a while, to make taking photographs in portrait orientation (not just portraits but also topics such as hand-held macro or nature) more comfortable. Does anybody have any experience with the off-brand variants of the MB-D17 and would you recommend any of them? The price difference is quite staggering to Nikon's own-brand vertical grip, which can be anything from 5-10x the price of the Neewer/Pixel/Meike variants (Nikon wants around 400 euro for it, and I'm finding it quite hard to find used ones for a more reasonable price).
I have the budget to buy an original MB-D17 if I needed to, but obviously if I could spend the 300-350 euro I would save with a third-party option on something else and get a similar user experience then I would prefer that.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
https://linustechtips.com/topic/1119391-nikon-d500-vertical-grips/
Buy the Nikon version, the 3rd party versions are poor build quality and don't work as well as the original.
There are countless threads all over the internet with people that have had BOTH and they all say the Nikon versions are better overall. Countless issues with the 3rd party versions. There will always be those who cheeped out and say they are fine while not telling people the issues they are having.... ;)
You get what you pay for in the end.
If you have the money as you say you do then get the original one.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
I can't remember the brand of the one I have for my D7100, but it was around $300 cheaper than the Nikon one and works flawlessly in all menus, etc.
So don't let the gentleman's opinion above scare you.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
I just checked mine -- it's made by Vello.
https://www.amazon.com/Vello-BG-N17-Battery-Grip-Nikon/dp/B0753RJGX2
It's only $90 USD!  That's less than a quarter of the Nikon price!
Yeah, part of my thinking is that I could have a box of a dozen of those break before it gets more expensive than one Nikon :)
Yeah I've got the same one, using it with the the D7200. Works like a charm. Zero issues. Seems pretty well built as well. Can't complain.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
I would say get the el cheapo one just to see if you get on with grips. I shoot macro and wildlife at least twice a week for many years now. I too thought grips would be a good idea. For me however they became extra weight and also intrusive. Especially when trying to get the lens level with a subject when macro shooting, such as shooting insects on a log or rail for instance, it prevented me from getting the low angle I wanted. So I ditched the idea.
That sounds like a sensible idea, thanks for the feedback :)
That's definitely a good point. I don't shoot anything macro (right now), but I can see where the grip would get in the way when shooting in landscape alignment. I shoot wildlife and portraits, some landscapes, so having the grip makes shooting in portrait orientation much, much easier.
I can attest to a grip being a bit of a problem if you want the camera as close to the ground as possible, but they are definitely worth having.  When I have it attached I usually use it instead of the camera to navigate menus.
