2x16GB 3200Mhz ram or 1x16GB 2666Mhz + 1x4GB 2666Mhz
Solved by Jurrunio,
Dont get the extra 4GB in this case. You'll only get 8GB of dual channel and 12GB of single channel, which has half the memory performance.
NukoTi ·
Posted in General Discussion0 -
FenixC ·
Posted in Troubleshooting3 -
FangerZero ·
Posted in Displays3 -
lilrino71 ·
Posted in New Builds and Planning1 -
3
4
play_circle_filled
Latest From Linus Tech Tips:
If Buying Isn’t Ownership Then Piracy Isn’t Theft - WAN Show June 20, 2025
