G.Skill same sticks with different names?
Rarok
Go to solution Solved by Princess Luna,
The difference is on the actual DRAM modules used inside them.
3 minutes ago, Rarok said:
F4-3600C18D-16GTZR
This one uses Samsung B-Die
6 minutes ago, Rarok said:
GTZRX
This also uses Samsung B-Die but it was AMD Ready validated.
F4-3600C18D-16GTZN
This one changes to SK Hynix A-Die.
I don't undertand the differences between some RAM sticks in G.Skill
Trindent Z RGB, Trident Z RGB (for AMD) and Trident Z Neo
F4-3600C18D-16GTZR
F4-3600C18D-16GTZRX
F4-3600C18D-16GTZN
Same voltage, same timings, same size, but of course the prices in shops are not the same (very little differences)
The colour is the difference.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
F4-3600C18D-16GTZRX - Trident Z RGB (For AMD)
F4-3600C18D-16GTZN - Trident Z Neo
Specs are identical, the RX says it's tested for AMD platform compatibility, while the N says full compatibility on the latest AMD Ryzen 3000 series processors on AMD X570 chipset motherboards. So I suppose the RX hasn't been specifically tested for Zen 2 (but probably still works), while the N is slightly newer.
The Neo and non-Neo look different, the AMD and non-AMD set will basically be the same
AMD memory was more important at launch, when it wasn't supported as well.
F4-3600C18D-16GTZR
GTZRX
F4-3600C18D-16GTZN
Personal Desktop":
Luna, the temporary Desktop:
The validation is something that I don't understand, should mean that someone is checking each stick manually and the others are packaged without any testing?
And about the Samsung or Hynix die, thanks, I'll google about that.
