Recently purchased a Samsung 4k monitor with DisplayPort input for use with Macbook Pro... then purchased a USB C to DisplayPort Cable (4K@60Hz) which works beautifully.
However, if I want to charge the MBP at the same time, have to use another usb-c port which looks messy!
The reason for this post, is am struggling to track down a HUB which, as the title, provides...
  • USB C input / output
  • USB C power input
  • USB C Video output to 4k@60hz
So in essence, would plug the hub into a single port on the MacBook, then plug in the MBP pro's charger into one of its USB-C inputs to provide charging and then plug in a USB C to DisplayPort cable, connecting the hub to the monitor, again to guarantee 4k at 60hz
Make sense? Anyone have this setup? If not, provide any links to such a hub?
19 hours ago, Graham Carter said:
Sounds as if it will do the job, but daaam its pricey
I found something cheaper :D
https://www.amazon.com/Anker-Adapter-Delivery-microSD-Chromebook/dp/B07HMLTCPL/ref=sr_1_3?keywords=usb+c+power+hub&qid=1572643021&s=electronics&sr=1-3#customerReviews
TB3 tends to be a lot more expensive, as it often requires several bridge chips.
(TB3 -> PCIe 4x -> bifurcation into something like 8 lanes -> ports)
USB does not require chips to bifurcate, and thus is cheaper. However it does have less bandwidth
