Hey guyz.
Sorry for my bad english.
I have an RX 570 4GB saphire ITX single fan.. i am using it for about 6 months now.. and now i wanted to overclock the hell out of it.. i don't why but my gpu throttles at exact 73c .. i did some testing and i am pretty sure that it is not power throttling.. it happens it exact 73c no matter what i do.. i used wattman for overclocking.. though I also tried msi afterburner but it is exact same.. i increased power and temp limit.. i think before increasing the power and temp limit it starts throttling at high 60s.. i tried flashing saphire rx 570 dual fan bios but i got the same result.. i have also replaced thermal paste.. i wanna know is there anyway to just get rid of my thermal throttling?
https://linustechtips.com/topic/1119237-rx-570-is-throttling-at-73c-help/
3 minutes ago, Muhammad Osama said:
Hey guyz.
it may simply not be able to clock any higher, this happens.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Just now, Muhammad Osama said:
but 73c is not that high temps for this gpu.
yes, but the GPU die itself only can go so far.
On 10/31/2019 at 2:12 PM, Muhammad Osama said:
Hey guyz.
73 degrees shouldn't throttle this GPU.
What are your overclock settings? frequency and voltages?
right now i found my gpu stable at 1360 core at 1085v and memory at 1750 at 850v.. i have to lower the voltages otherwise it will it 73c immediately and starts throttling
That's interesting...right now I have my RX570 set at 1380 mhz core and memory at 1900. The highest temperatures I've seen it reach is 70c but I have the fans almost maxing out when the gpu is at full load.
If you are using Wattman, you can make your fan curve more aggressive. Just beware, your PC will be much louder.
I have already set my fan speed at 100%.. i mentioned in my post that i have a single fan rx 570 .. it's a small card with small heatsink and one fan.. and a tdp of 120w..
This sentence alone is worrisome enough...
13 hours ago, steelo said:
"I have an RX 570 4GB saphire ITX single fan.. i am using it for about 6 months now.. and now i wanted to overclock the hell out of it"
Thanks for everyone respone.. amd release new driver update on 4th November.. and that solve me issue now my card is not throttling
