One shot at build cannot screw up.
Anything missing or not compatible?
CPU: AMD Ryzen 7 2700X 3.7 GHz 8-Core Processor  ($191.56 @ OutletPC)
CPU Cooler: Noctua NH-U12A 60.09 CFM CPU Cooler  ($99.90 @ Amazon)
Motherboard: Asus ROG STRIX B450-F GAMING ATX AM4 Motherboard  ($119.89 @ OutletPC)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($64.98 @ Amazon)
Storage: Corsair MP600 Force Series Gen4 1 TB M.2-2280 NVME Solid State Drive  ($189.99 @ Newegg)
Video Card: XFX Radeon RX 5700 8 GB Video Card  ($329.89 @ OutletPC)
Case: Cooler Master MasterBox Pro 5 RGB ATX Mid Tower Case  ($67.98 @ Amazon)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($99.89 @ OutletPC)
Monitor: AOC C24G1 24.0" 1920x1080 144 Hz Monitor  ($144.99 @ Amazon)
Build for gaming and home computing, web browsing. Budget is around 1500
https://linustechtips.com/topic/1119204-any-glaring-issues-with-a-potential-build/
  • U14S is cheaper, and better.
  • Why are you getting 2 144hz monitors? You can save money by just getting one.
  • The 3600 might be a better choice.
  • You're waiting for Black Friday, yes?
Welcome to the forum.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
PCPartPicker Part List: https://pcpartpicker.com/list/g2gcYH
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor  ($234.27 @ OutletPC)
CPU Cooler: Noctua NH-U12S chromax.black 55 CFM CPU Cooler  ($69.95 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($114.99 @ Best Buy)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($76.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($95.99 @ Amazon)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  ($413.98 @ Newegg)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.89 @ OutletPC)
Total: $1474.02
Generated by PCPartPicker 2019-10-31 12:32 EDT-0400
windows keys can be found for 5$ or so
Total: $1474.02
The X processor is a waste of money...
comes with free game and overclocks itself. depends whether OP wants to do manual OC (in which case should go with 3600) or not (go with 3600X). Either way, 3600 is better than 2700 for gaming.
11 minutes ago, yaop117 said:
it doesn't really make sense to get two 144hz monitors IMO since i assume you will only be using one for gaming and the other for miscellaneous tasks.
yeah, for the price of two, could probably upgrade to either an ultra wide or a 1440p, both options being better than the initial one
Only makes sense if he wants that game. Even then, the price difference isn't far off the cost of the game.
What is the U14S and why is it better? Two monitors provides some functionality I need for some work stuff. The 3600 instead of the X? Why ? Are prices better at Black Friday?
thank you for the feedback!
Kind of depends where you live; if you live somewhere that has Black Friday sales, absolutely. Every build I've done on a Black Friday has either gotten substantially better parts at the same price, or saved hundreds of dollars.
The U14S is a Noctua cooler. 140mm fans instead of 120mm, and it keeps the CPU cooler.
Yes, but you don't need 2 144hz monitors, only one for gaming. The other can be a regular 60hz monitor.
The 3600 will OC to the same point as the X; the X is a needless waste of money.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($194.79 @ OutletPC)
CPU Cooler: Scythe Mugen 5 Rev. B 51.17 CFM CPU Cooler  ($48.89 @ OutletPC)
Storage: Team MP34 1 TB M.2-2280 NVME Solid State Drive  ($104.99 @ Newegg)
Case: Metallic Gear Neo Air ATX Mid Tower Case  ($55.98 @ Newegg)
Power Supply: Gigabyte 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($69.99 @ Newegg)
Monitor: Acer ED7 34.0" 3440x1440 100 Hz Monitor  ($399.99 @ B&H)
Total: $1480.59
Generated by PCPartPicker 2019-10-31 21:43 EDT-0400
