Gracefully Shut down Unraid VM on ESXi with power button
Solved by Jarsky,
I don't believe ESXi has the functionality...you could probably create a script to send the command to shutdown all VM's and then shutdown the host via SSH or PowerCLI so you could shut it all down from a remote machine (e.g your PC or phone). You'd just need to make sure you keep VMTools up to date so it can interact with it.
KeradSnake ·
Posted in Tech News1 -
4
4
5
gotopepik ·
Posted in CPUs, Motherboards, and Memory7 -
TedNukem ·
Posted in Programs, Apps and Websites3 -
13
n0rf114 ·
Posted in Power Supplies16 -
7
play_circle_filled
Latest From Linus Tech Tips:
I put a $3000 GPU in my Average PC... It Was a Mistake
