Hey there guys, hope you're doing well, I wanna buy some RGB Cooling for my Masterbox 3.1 Lite TG but I don't know if Pure 12 ARGB from thermaltake is compatible with my motherboard if anyone could help please?
Fans: https://fr.thermaltake.com/pure-12-argb-sync-radiator-fan-tt-premium-edition-3-fan-pack.html
Motherboard: Gigabyte B450M-DS3H
https://linustechtips.com/topic/1119033-pure-12-argb-fan-help/
The fans will work fine, however you will not be able to control the color through software since your motherboard does not have a 5V ARGB header. You can use the included ARGB controller though, and that will let you cycle through ThermalTake's factory configurations.
Main Server: CPU: AMD Ryzen 9 5950X | RAM: 64GB (2x32GB) Corsair Vengeance LPX DDR4-3200 | Motherboard: AsRock X570 Phantom Gaming ITX/TB3 | Storage: 256GB Kioxia NVMe | GPU: SPARKLE Intel Arc A380 Genie | Cooling: Thermalright Phantom Spirit 120 EVO | Case: 3D Printed Mini-ITX Case | PSU: Lian Li SP850
https://linustechtips.com/topic/1119033-pure-12-argb-fan-help/#findComment-13009673
5 hours ago, GoldenBlack said:
You mean that it would still work with the default controller?
As shown here: https://youtu.be/zGGPaxU8uXo ?
The controller which comes with the fans will work with the fans. Your mobo doesn't support ARGB.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1119033-pure-12-argb-fan-help/#findComment-13010167
Alright thanks mate, I guess i'll still go with that one if it "works" I'm fine with the fan modes that are shown on the vidéo above, if they work still
https://linustechtips.com/topic/1119033-pure-12-argb-fan-help/#findComment-13010230
Why not go for the Pure Plus 12? They come with a controller that can control your fans and lighting and give you better control of the fans in my opinion. You need a molex power and a USB 2.0 header, though.
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
https://linustechtips.com/topic/1119033-pure-12-argb-fan-help/#findComment-13010235
1 hour ago, GoldenBlack said:
Don't realy have much of a stock diversity where I come from @Chiyawa
Ooo, okay. Sorry to hear that.
https://linustechtips.com/topic/1119033-pure-12-argb-fan-help/#findComment-13010338
