2 minutes ago, Dandapani108 said:
my mobo doesn’t support it
oh it does, fan splitters they are called.
Desktop benching:
Primary PC:
Just out of curiosity; How many fans can you max connect to one splitter ?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
as long as their max current draw dont exceed 1A (2A if specified)
Desktop benching:
I think 5 fans is current limit. After that headers start to act up. Though max is still 1A per header unless otherwise specified.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
3 hours ago, Dandapani108 said:
Im using a 600watt psu with a rtx 2060super
below are the fan specs-
Operating Voltage
FAN: DC6.0-13.8V; LED:DC9.0-13.8
Rated Current (A)
FAN: 0.18A±20% ; LED:0.30A±20
Will connecting these 2 fans to the psu cause any problem?
According to that the fan with it's LEDs will draw 0.48A so 0.96A for two together on one header . You're fine to connect two of them to your motherboard using a splitter like @Fasauceome linked above.
Connecting them to the motherboard fan header would be recommended however IF you want to run them directly from your PSU you'll need a molex to fan adapter cable, but doing so means you won't be able to control the fan speeds from your motherboard, they will just run at full power all the time
Ryzen 7 2700X  | Gigabyte RX5700 XT | ASUS TUF B450M | HyperX Fury 2x16gb 3200MHz |  CM MasterBox Lite 3 (Mesh Modded) | Corsair MP510 960GB | Be Quiet Pure Power 11 700w
Operating Voltage
Rated Current (A)
To PSU none. Single SATA or molex has something like 5A.
