There is a mATX case like the same hight right?
GIGABYTE B550I AORUS PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 16GB (2 x 8GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/1118754-matx-4-slot-element-q/
More like that hight.
https://linustechtips.com/topic/1118754-matx-4-slot-element-q/#findComment-13007227
Look into HTPC cases like Silverstone GD series.
https://pcpartpicker.com/product/RGZQzy/silverstone-case-gd06b
https://linustechtips.com/topic/1118754-matx-4-slot-element-q/#findComment-13008034
I wish they put the PSU on the other side, after the slots is odd placement. Womder if I could have Protocase move the PSU space befpre the motherboard?
https://linustechtips.com/topic/1118754-matx-4-slot-element-q/#findComment-13008326
It will be expensive, but probably feasible.
https://linustechtips.com/topic/1118754-matx-4-slot-element-q/#findComment-13008524
