HDMI TO VGA or graphic card issues. HELP
Go to solution Solved by Xiee,
It might be the adapter. I had something happen to me a while back since I use a secondary old monitor that still uses VGA so I had to get an adapter.
I ended up getting another adapter and the problem went away.
I just bought this adapter from amazon and noticed that the screen would flick on and of randomly. It kept getting worse until the monitor would lose signal. I cant tell if its my gpu or adapter. https://www.amazon.com/gp/product/B07NWDN75C/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
  • CPU
    AMD Ryzen 5 2600x 3.4 GHz 6-Core Processor
  • Motherboard
    Gigabyte B450 AORUS M Micro ATX AM4 Motherboard
  • RAM
    Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
  • GPU
    Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card
  • Case
    Thermaltake Versa H18 MicroATX Mini Tower Case
  • Storage
    Crucial MX500 500 GB 2.5" Solid State Drive
  • PSU
    Corsair VS 550 W 80+ Certified ATX Power Supply
  • Cooling
    Deepcool Gamerstorm Captain 240 PRO
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1118635-hdmi-to-vga-or-graphic-card-issues-help/
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
I will return the adapter and see what happens then. I was hoping to wasnt the gpu.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
