Undervolting Nvidia, temperature, power, methods.
Hello
I found a recent test of RTX2070Super vs. 5700XT GPU, where undervolting was covered (ComputerBase, in German)
I am impressed by the efficiency of the Nvidia card when undervolted. How can one do it for NVidia cards? I know MSI afterburner, but what is the precise method (ie.: CTRL+F will display the voltage-frequency curve, to fine-adjust the points. or is there a simpler method, for instance, just setting up -10% voltage?)
I currently don't have Afterburner installed, but is there anyone, who had been undervolting Nvidia GPU via afterburner, and has experiences with impromevement in power consumption and temperatures?
Any input is welcome. Thanks in advance anyone for the response.
Life is really challenging. I don't always suceed: )
changing the voltage slider just changes the offset so if the card wanted to, it will justdump more power to reach a specific frequency so it wont really do anything.
changing the curve to be flat at the end will force a maximum voltage therefore reducing the voltage needed to reach a specific frequency
okay. But how did the authors of the article reached that impressive drop in power consumption via afterburner? With limiting power and voltages, or is there other method for this?
optimized oc on a lower power limit will do the job
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
thanks. And what do you think of editing the voltage-frequency curve? : ) worth it for the lower temps?
