Not able to control new noctua fans
Go to solution Solved by awesomeboy354,
2 minutes ago, WoodenMarker said:
Have you tried reverting to default motherboard settings first? Are you touching any other settings?
FYI, you can quote more than one post at a time.
hey nvm I just solved it apparently I need msi commend center to control the fans THANKS FOR ALL YOUR HELP
Hello, I recently purchased 2 noctua case fans for my PC in header sys fan 1 and 2 and I have been struggling to control there speed. I am trying to use speed fan to control them but the fans don't show up anywhere on speed fan. The fans show up in the BIOS and in hw monitor and it does say the speed in which they are spinning but they don't show up in speed fan at all. I have turned off smart fan control in my msi b250 PC mate bios but it doesn't change anything and I am stumped. Anyone have any ideas that could help or fix this issue? Thank you in advance!
https://linustechtips.com/topic/1118605-not-able-to-control-new-noctua-fans/
Which fans do you have?
Why not just use the motherboard fan controls?
I have tried to use the mobo to control them but whatever I changed nothing would happen  I also have some Noctua nf-p12 redux pwm fans
What settings have you tried? Have you checked if control works by just setting them to 100% rpm?
Are you only using the motherboard fan controls without running other control software?
Speedfan doesn't support many of the newer control chips. If you don't want to use MSI software, then you have to pay for Argus Monitor.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Its not that I don't like to use the bios to control them its just that it doesn't work I have changed every thing and the fans don't change in speed
I am using the bios and I set them to 100% and nothing happens
