One way I can think about is to use some sort of ghetto fan controller that fakes RPM range...
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
32 minutes ago, Erbu said:
The size doesn't matter the fansa re just too low rpm so it thinks the fans broke and it shuts down
then just power the fans straight off the 12v rail, and disconnect the fans or something
Also, 6-pole fans (noctua industrials, be quiet SW3 double the reported fan RPM so that could work)
4 hours ago, Firewrath9 said:
Thats not what I am looking for... I want to use silent fans not reduce the amount of noisy fans
well less noisy fans = less noise but I found something for spoofing the fan signal
https://homeservershow.com/forums/topic/7294-faking-the-fan-signal/?/topic/7294-faking-the-fan-signal/?p=79985
